HeatMap?
HeatMap?
Const32
HeatMap?
Const32
[ FlexSim 23.1.2 ]
Can someone make a HeatMap in my model and explain me how can I make it? I know that A* navigator can create this map.
I wanna see the HeatMap of my crane for knowing whitch trip has frequented most.
HeatMap.fsm
Thanks!
jason_lightfoot_adsk
A solution example for creating a heatmap for any object and transport - regardless of navigator type.
anjunittur123
Hey @Const32
Here is a basic example of HeatMap in a model using crane.
To generate a heatmap, you need to use A* navigation and from the A* navigation properties under "Setup" tab, add all the other members of the model using the sampling icon as shown in the below picture.
Double click on the A* navigation object, under the "Visual" tab you will have the HeatMap box. Check the dialog box and set the other parameters as needed , this will generate a HeatMap for the crane in the model.
Here is an attached example model. A-star_crane heatmap.fsm
Hope this is clear.
natalie_white
Hi @Const32, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
