GUI error
GUI error
singersaJK6TN
GUI error
singersaJK6TN
Hello Team,
I am getting the following errors in the console when I run my model which is combination of process flows and 3D model. I am not able to debug this.
time: 106.688285 exception: FlexScript exception: Exception caught in TreeNode::callMemberFunction() c++/dll execution. Throwing... at VIEW:/active/DockingGUI/TabPane/TabControl/ProcessFlow>eventfunctions/OnDraw at line 0 c: VIEW:/active/DockingGUI/TabPane/TabControl/ProcessFlow
time: 130.877029 exception: Exception caught in TreeNode::callMemberFunction() main function. Throwing...
time: 130.877029 exception: FlexScript exception: Exception caught in TreeNode::callMemberFunction() c++/dll execution. Throwing... at VIEW:/active/DockingGUI/TabPane/TabControl/ProcessFlow>eventfunctions/OnDraw at line 0 c: VIEW:/active/DockingGUI/TabPane/TabControl/ProcessFlow
time: 134.137580 exception: Exception caught in TreeNode::callMemberFunction() main function. Throwing...
time: 134.137580 exception: FlexScript exception: Exception caught in TreeNode::callMemberFunction() c++/dll execution. Throwing... at VIEW:/active/DockingGUI/TabPane/TabControl/ProcessFlow>eventfunctions/OnDraw at line 0 c: VIEW:/active/DockingGUI/TabPane/TabControl/ProcessFlow
time: 140.279550 exception: Exception caught in TreeNode::callMemberFunction() main function. Throwing...
FelixMoehlmann
The first guess would be that a non-activity node ended up inside the Process Flow (via a wrong reference in an unload activity for example). Try checking the Process Flow subnodes in the tree to see if you find anything that doesn't belong.
singersaJK6TN
Thank you. This issue got resolved. The error was in the push to list token definition.
