Global table as parameter in experimenter
mapo19
mapo19
[ FlexSim 24.1.0 ]
Hello everyone!
I have a model that uses several global tables to determine the route, speed, consumption etc. These tables are called via code snippets like the one in the picture below and in several other process blocks.
I am wondering if it is possible to set up an experiment that can call in new tables and run the experiment with these new tables instead of manually changing each table in all blocks and running it as normal. For example (with the tables from the picture in mind), an experiment that replaces all "DumpCharger", "ChargerLoad", and "LoadDump" with "DumpCharger1", "ChargerLoad1", and "LoadDump1" in the process flow blocks that uses them.
Thank you for your time and expertise!
moehlmann_fe
You can use an "Expression" type parameter. Theoretically the parameter could then already contain a reference to the table node. But since that would be more complex when entering the values in the scenario table and also less readable I mostly just set the table name as the parameter and then always refer to that parameter when calling the table.
Table dumpChargerTable = Table(Model.parameters.DC_TableName);
mapo19
Hello!
I have tried and tested but have not gotten the desired results. However, I will test some more tomorrow to see if I can get it to work!
Thank you for answering!
moehlmann_fe
Here's a small example in which the process times of a processor are determined by one of three tables.
table-parameter-fm.fsm
mapo19
I got it to work. Thank you for your time and expertise!
mapo19
Just wondering, but is it possible to refer to two tables in one value? For example, writing "DumpCharger1" && "DumpCharger2"?
moehlmann_fe
You can write an array into the expression parameter. Though you will handle the value accordingly when reading the parameter.
