GIS Module: Dynamic Creation of Trucks
emmanuelvasquezsand
emmanuelvasquezsand
[ FlexSim 23.0.15 ]
Hello everyone,
I am starting to create a GIS demo using Process Flow. My idea is to dynamically create trucks that follow a route (with more than one point). However, when I create the object and connect it to a GIS point, its visualization is incorrect (a white dot appears instead of the truck shape). What could be the error?
I am attaching the model to clarify what has been mentioned.
I appreciate your help in advance.
23.0.14_ModelGIS.fsm
moehlmann_fe
Observer
Observer
The truck flow item does not have a shape assigned to it and instead consists of multiple components (so that the wheels can be animated independently of the rest). The GIS map only displays the shape though.
If you create a new TE flow item and assign it the full truck shape "Truck.ac" (the one you already use for the Truck1 object in the model) it will display on the map.
23014-modelgis_1.fsm
emmanuelvasquezsand
Hello @Felix Möhlmann
Thank you very much for your prompt response. It works perfectly.
