Getting length of array label
christine_b
christine_b
[ FlexSim 17.2.5 ]
I have an item with an array label that typically has 18 elements. If, however, the item is released early then the array label will have less than 18 elements. I am looking to use a for loop to access the elements in the array but I need to know the length/size of the array. Something along the lines of "arraysize" or "array.length"?
I have searched the help forums and the User Manual but to no avail.
Any help would be much appreciated. Thanks!
joerg_vogel_HsH
Your guess is right. array.length is the property which tells you the number of elements in an array.
You find the classes, commands, methods, properties under the FlexScript Class reference in the User Manual.
christine_b
Ooh - got it!
Thanks for pointing that out.
