Getting error while setting state under MTBF MTTR function?
rajankur6494
rajankur6494
[ FlexSim 23.1.0 ]
Hi Team,
I have made some changes in the regular logic. Here, ports of objects are closed instead using stop function. I am trying to set state of object in this case. I don't know if we can do it. I am getting error as below:
Can you help me in this?
Thank you!
moehlmann_fe
You are trying to a set a state on the MTBF/MTTR. current generally refers to the object in whose attribute tree the code you are editing is situated (ownerobject(c) -> c is the code's node -> current is the 'owner' of that node).
The object that the down time is applied to is downobject.
rajankur6494
Ok @Felix Möhlmann!
Makes sense.
rajankur6494
Hi @Felix Möhlmann;
One quick question, since we are setting it manually how we can ensure that it will come in the previous state once resumed.
Do I need to write code or will it happen automatically?
Thank you!
jason_lightfoot_adsk
You'd have to set it yourself. But use the resume since then it will do it for you - use the code to release the item from the other post.
