get accumulated time in a specific state - time table
marc_r5
marc_r5
[ FlexSim 22.1.1 ]
If I want to get the total production time of a simulation, I cannot use directly "Model.time" function, because it takes the whole time between start and end.
I need to accumulate the time in a specific state that I have defined in my time table, to substract to the total time.
What functions are there to get this info?
Thanks.
moehlmann_fe
To get the time an object spent in a given state you can use the following command:
Object.stats.state().getTotalTimeAt(stateName/stateNum);
You could theoretically also read the time directly from the node that stores the timetable information.
// Get the timetable table node
Table timetable = Model.find("/Tools/TimeTables/TimeTable1>variables/table");
int stateNum = 12;
// Query to sum up the duration of a given state up to the current model time (completed blocks only)
Table queryResult = Table.query("SELECT SUM(Duration) FROM $1 WHERE State == $2 AND Time + Duration < $3", timetable, stateNum, Model.time);
// If the query found something, return it
if(queryResult.numRows)
return queryResult[1][1];
