Get access to the OptQuest algorithm
maryamh11
Message 1 of 11
maryamh11
[ FlexSim 24.0.0 ]
How can I access and modify the optimizer's algorithm to test different results or implement alternative algorithms?
I found these two posts, but they are from 2017 and didn't answer my question.
https://answers.flexsim.com/questions/44888/is-there-a-way-to-access-andor-change-the-algorith.html
https://answers.flexsim.com/questions/34782/optquests-inner-workings.html
Replies (10)
Message 2 of 11
joerg_vogel_HsH
@Maryam H2, what do you expect, that you can modify or which algorithm do you want to use?
Message 3 of 11
jason_lightfoot_adsk
The answer about Optquest will be the same as Jordan posted in 2017 - nothing has since changed in that regard.
You may additionally want to explore reinforcement/machine learning for which FlexSim has some support in recent versions. (I've yet to see a convincing example of this being worth the effort over implementing a tailored/custom heuristic)
Message 4 of 11
maryamh11
@Joerg Vogel the first step for me is to understand how the current algorithm's logic in optimizer works. And then test some changes; for example if the current one is using GA to find optimal solution I want to change/modify fitness function, or use a completely different algorithm such as Tabu search and PSO and compare the results and see how use of algorithm/parameters can change the results.
Message 5 of 11
maryamh11
@Jason Lightfoot good idea! I'm also willing to explore the RL/ML applications in my model. what are the supports in recent version you are referring to?
Message 6 of 11
\The link I gave is 22.2 onwards - much later than the version17 links you included in the question.
Message 7 of 11
maryamh11
@Jason Lightfoot I see that in the RL training page the training algorithm is PPO (proximal policy optimization) which is a RL algorithm, however heuritics algorithms such as GA , Tabu search is not well alighned with this type of RL algorithms since heuristics are rule-based algorithms which replace the exhaustive search for optimal solution while algorithms like PPO optimizes the policy by performing gradient ascent on expected returns. Did you mean to improve current PPO / change of PPO to something else or really is there a way to implement heuristics algorithms and compare the outcomes?
Message 8 of 11
I meant vs. writing your own algorithm/rules in FlexScript - not using RL.
Message 9 of 11
maryamh11
@Jason Lightfoot Do you mean not using RL training module at all or part of it? can you give an example how that's possible?
Message 10 of 11
Ram7
How can I contact you @Jason Lightfoot
Message 11 of 11
In the past I've used a simple heuristic to decide how to distribute material across reels to satisfy rules about what can be supplied to a customer while minimising waste.
Another example is a sequencing problem to minimize color changing setup times (attached). Often you'll find suggestions to use genetic algorithms or reinforcement learning to find optimal solutions for these types of problems, but for some cases a fast and powerful heuristic may be better.
minSetupSequence.zip
