Generate different random numbers every time I run a model
lucas_braga1
lucas_braga1
[ FlexSim 7.5.4 ]
When I run a model using commands such as duniform(...) or randint(...), it generates a sequence of random numbers. But when I reset the model and run again I get the same numbers again. Is there any way to get a new sequence of random numbers when I reset the model?
jing_chen
You should uncheck the "Repeat Random Streams" in Statistics menu.
Matthew_Gillespie
You should use the experimenter. And run multiple replications. Unchecking the repeat random streams option is not advised since it makes it nearly impossible to debug your model.
Please read my response to this similar question: https://answers.flexsim.com/answers/26036/view.html
Matthew Gillespie
FlexSim Software Developer
