General process Flow tips and tricks for my simulation model
hakon_l
hakon_l
[ FlexSim 22.2.2 ]
Hi!
I'm posting here once again for some help and tips, since there are so many knowledgeable and helpfull people here. Thanks for everything!
My focus has shifted somewhat since I've been able to complete my simulation model (thanks to your help!) and the next thing is to make a Process Flow model of it. Which leads me to why I am posting here again:
I've been reading the guides and seeing examples on youtube etc., and I would like to ask a question that may be off help to several people, since its a rather open and general question:
Are there any general tips / tricks / questions I should think about or ask myself when setting up the Process Flow model?
I guess I would have to assess what kind of process flow is right for my case?
- Is Sub-flow a smart choice for machines which are used by many objects in the simulation?
- Do I need to make a 3D model at all? Can I just make a Process Flow model without the 3D-part?
- How should i organize the different activities? (Machine resources can be listed together for instance - But are there other natural ways to organize the content in a process flow?)
In advance thanks for the input and help - Sincerely!
PS! I've added my simulation if it is easier to give me feedback on something more concrete:JobShopModel V1.0.fsm
kavika_faleumu
Hey @Håkon L, it's great that you're looking for some best practices in Process Flow! I hope some of my insights will be helpful to you (and anyone else who reads this post).
Process Flow (PF) is a powerful tool that can be used to build entire models - you don't need a 3D view if you don't want one. It adds a lot of customization that you might not find easily in 3D objects. However, I believe the best models are built using both 3D and PF logic; there are many things that the 3D objects inherently do to make your life easier, and it helps you visualize your processes.
There are four types of PF: General, Object, Sub-Flow, and Person.
  • If you want to build a model from the ground up, I would start with a General PF - this is a blank slate for you to add "activities" that build your logic.
  • If you have multiple machines/objects that need to perform identical tasks, then an Object PF is what you're looking for. You can build the logic you want your machines to have and then "attach" those 3D objects to the Object PF. Each attached object will then use that Object PF as its own brain.
  • If you have some functionality that you don't want to repeatedly build but you want to reuse, a Sub-Flow is what you want. If you're familiar with programming terms, Sub-Flows are like functions or subroutines - they're an isolated piece of logic that can be called upon to execute a specific task. One example might be a Sub-Flow with logic to have an Operator load boxes from a given queue.
  • A Person PF is a type of General PF that is specifically built for the logic of people in the model. It's generally used for Health Care logic where you have patients and staff navigating in a clinic/hospital.
To build PF logic, you drag and connect "activities". Activities are literally the building blocks of PF. Each activity executes a unique piece of logic, so choosing the right activities to connect is important. PF uses things called "tokens" which are represented by green circles (you can change the visuals of these as well). Tokens are what "drive" your logic - they navigate through each activity and execute the logic there, moving onto the next activity when they're done.
With that in mind, you should organize your activities in a way that makes sense to you. If it makes sense for your tokens to represent boxes moving through a Conveyor System, then build your activities around that. If it makes sense for tokens to represent your machines as they execute their logic, build around that. If your PF begins to be confusing to you, then change it. If you're confused on how to build PF logic, checkout the different activities available to you and experiment with them in a smaller model. I even recommend building your logic out in pen and paper first and then "translating" it to PF.
I hope these help tips helped you. Let me know if you have more questions.
Jeanette_Fullmer
Hi @Håkon L, was Kavika F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
