Format of the graph axes
borja_lorenzo4278
borja_lorenzo4278
[ FlexSim 24.1.1 ]
Hello
In the graphs of the attached model, you can see that some have a format of minutes on the X-axis, while others use date and time.
The ones with date and time are created directly from the graph library. How can I modify the units/formats of these standard graph axes?
The ones with a minutes format come from a statistics collector.
20240801_CP11_libro_FlexSim_Jidoka_5.fsm
This question is related to a previous discussion: input vs time for sink to dasboard using statics collector - FlexSim Community
moehlmann_fe
For charts with a date time value on the x-axis, you should be able to switch to "Show Duration" with the time unit of your choice in the chart's properties.
