Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Folders in dashboard dropdown
pasichp
pasichp
[ FlexSim 24.1.0 ]
When you click on the Process Flow dropdown on the top bar, the process flows appear in folders, organized just like they are in the Toolbox:
Whereas Dashboards are displayed in a flattened, folder-less structure:
Is there an option to make the Dashboards dropdown display a folder-based structure?
joerg_vogel_HsH
@Przemyslaw Pasich, Process Flow in Main Menu is a list of Templates. If you drag them into your model they will be listed as items in your toolbox in a section of Process Flows. The Dashboard Main Menu has got two entries. Once you choose one, they are listed as chosen Process Flow Templates equally in Toolbox as editable Dashboards. The behavior is identically for both structures in FlexSim. I do not see any differences.
pasichp
Hi Joerg, I don't think I did a good job explaining my question - I edited it for clarity. Could you please take another look at it?
jason_lightfoot_adsk
We're not sure if this is intended to work the same way as the ProcessFlows but it would make sense. We'll add case in the issue tracker to review the behaviour.
