FluidGenerator setting by using flexscript
danielhsu2014
danielhsu2014
[ FlexSim 24.2.0 ]
How can I set the Refill Mode and Refill Rate for a Source object in FlexSim using FlexScript, similar to how I set the maximum content with setvarnum(newObj, "maxcontent", 10);?
SebastianCanasV
Hey @Daniel ,
You can use:
// Refill Mode: 1 Continuous Refill - 2 Complete Refill When empty
setvarnum(newObj, "refillmode", 1 /*1 or 2*/)
//Refill Rate
setvarnum(newObj, "refillrate", value)
danielhsu2014
Thank you so much. How about output port, How can I set the maximum object and maximum port rate in flexscript? Thank you for your help!
SebastianCanasV
@Daniel ,
// Output ports - Maximum Object
setvarnum(newObj, "maxobjectoutrate", value);
// Output ports - Maximum Port Rate
setvarnum(newObj, "maxportoutrate", value);
