[ FlexSim 17.2.5 ]
Can someone help me set up a water purification and bottling plant?
[ FlexSim 17.2.5 ]
Hi @Robert M2,
If you're looking for someone to build your model for you, you might contact your local FlexSim distributor. They may have consulting services, or know of FlexSim simulation consultants that they could refer you to.
If you're specifically looking for someone to answer your questions and help you build your own model, then you're in the right place. However, your questions need to be more specific. We don't know anything about the processes, resources, or constraints in your facility.
Instead of asking a general, open-ended question, please focus on single, specific questions you have in building the model. Each question here at Answers should be focused only on a single issue. Please see our Best Practices.
If you just need help getting started, the in-software tutorials are a good place to start, and your local distributor is your contact for getting FlexSim training.
Good luck!
My process of water purification and bottling, needs to process 12000 liters of water daily, my specific question is in the tanks How to make them charge 12,000 liters and expose?
I'm not sure I understand what you mean by "charge 12,000 liters and expose"? Could you clarify what you are looking for a bit further?
Nevermind, I just saw your other question post about this same question.
