floworks oil and gas separation process using flexsim
ruwaida_a
ruwaida_a
[ FlexSim 18.1.2 ]
Am working on oil and gas separation process using floworks, is that possible? if yes please how do i impute the parameters for the flow. please i need urgent help
ruwaida_a
Here is a picture of the setting. am I doing it right? what can the separator equipment be replaced with?
dj_moens
It is hard to see if you are doing 'it right' as from your question I do not know what you are trying to achieve.
You probably split on flow % at the seperator. This will be maintained as long as downstream objects are able to receive.
By the way if you are using vbersion 2018.1, it might be good to upgrade to the latest version.
Rgds
DJ
Ben_WilsonADSK
Hi @Ruwaida A, was dj.moens's answer helpful? If so, please click the red "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation. If you comment back, attaching your model will be quite useful for those trying to help.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
