FloWorks: How to record the current content of a group of tanks in floworks
Kelvin_Barbosa
Kelvin_Barbosa
[ FlexSim 24.0.1 ]
reference tank group.fsmHi,
I'm trying to collect the statistics of the current content of a group of tanks using 1 token.
I did the following test using processflow: I created a token at time 0 with two assign labels referencing the group of tanks and tried to record the current content, but it didn't work.
Thank you for your support in advance
patrick_zweekhorst
If you want to get the content of a tank you need to cast the Object to a FlowTank (something like: token.Tank.as( FlowTank ).content.)
But since you are looking at a group I think you will need a short for loop or run subflow to get the content of all tanks. I would change the assign labels to something like:
Object current = param(1);
treenode activity = param(2);
Token token = param(3);
Variant assignTo = param(4);
string labelName = param(5);
treenode processFlow = ownerobject(activity);
Group tanks = token.lb_Tank;
double content = 0;
for( int i = 1; i <= tanks.length; i++ )
content += tanks[ i ].as( FlowTank ).content;
return content;
Hope this helps
Kelvin_Barbosa
thanks patrick
mischa_spelt
Just to add to @Patrick Zweekhorst 's answer: in the Dashboard library there is also an chart template "Group Content" that will group multiple tanks (default: by product) and display the content as a line chart vs time, or the current value in a bar chart or table.
If you want you can click "View Table" in the Advanced section of the chart properties to access the data, or "Install" the chart template to see how we did it.
