[ FlexSim 19.2.2 ]
There is a requirement for a barge to be tow by tow tugs from an anchorage to another anchorage. This has being modeled using "Use transport" to call a tow tug (as transport) to transport the barge (as flowitem). This seems to work well, however the statistics of the Berth object which is used to model the anchorage does not track waitingfortransport time, though the profile have the state in the list. Is this a bug?
Is there a workaround? That is, how can we track this time instead?
We have the trigger points of "End Processing" trigger to "On Exit" trigger but tracking the lapse time between these two triggers seems to also include the time when downstream object is not ready to accept the vessel which is not desirable.
Attached is a model modify from tutorial 3.: floworks-tut3-sample-issue-192-transport.fsm
waitingfortransportstatemissing.png. Underneath the moving vessel is a transport named towtug as shown in the attached pic.
