FLEXSIM WEBSERVER
FLEXSIM WEBSERVER
swami_p2
FLEXSIM WEBSERVER
swami_p2
[ FlexSim 20.0.0 ]
I want to use flexsim webserver and i m following the instructions given in the manual.
I have setup flexsim webserver configuration still webserver front page is not coming and also http://127.0.0.1/ is not working.
I have attached the screenshots for reference. Please suggest ,thanks
allister_wilson
The error message in the server console states : Unable to locate the FlexSim Data Directory.
Your config file has FlexSim Data Directory set as %AllUsersProfile%\FlexSim\FlexSim18.2.
Presumably that isn't a valid path, if you have never installed FlexSim 18.2 then that folder has probably not been created.
You need to update the config file to point to the correct data folder. Since you're using FlexSim 2020 that will likely be %AllUsersProfile%\FlexSim\FlexSim20.0.
