[ FlexSim 21.0.7 ]
Hi, I am starting to work with Web Server and I have a problem. I manage to execute the JSON file provided in the manual and the FlexSim instance runs correctly. When I finish working I close everything (FlexSim and Web Server).
However, when I want to test again, I run the Web Server and automatically open the instances that I was testing before, as if they were preloaded and run one after the other. Even if I close them, they run again.
What could be happening? As far as I understand the Web Server listens to the request that I send, but in this case I am not sending anything, just to run the Web Server instances begin to open.
Thank you very much.
