FlexSim takes a long time to process
tsuji_ryusuke
tsuji_ryusuke
[ FlexSim 22.0.5 ]
The customer creates an object by referring to the global table information of about 450,000 rows.
I am trying to increase the processing speed by hiding the Model tab, but it still takes time.
The attached sample model is a model that reproduces the fact that it takes time.
Is there any effective measure to increase the processing speed?
LargeGlobalTabledata.fsm
jason_lightfootVL7B4
You're creating 450000 tokens you don't need - just use a code snippet with a loop in a CustomCode instead:
Table t=Table("GlobalTable1");
Object box=Model.find("Tools/FlowItemBin/Box/1");
Object newbox;
for (int n=t.numRows;n>0;n--) {
    newbox=createcopy(box,model());
    newbox.row=n;
tsuji_ryusuke
@Jason Lightfoot ,
It turns out that creating unnecessary tokens takes time.
Thank you for your advice!
joerg_vogel_HsH
A token contains some data nodes. Those nodes are increasing a consumption of RAM space in a computer system. RAM is a limited resource in a system. Data is transferred from RAM to a CPU Core, which takes time, too. If you can limit consumption of RAM and Core processing time by not creating unnecessary data, a model runs faster.
