FlexSim Still Crashes When Copying Label Names
arunTTT2P
Message 1 of 14
arunTTT2P
[ FlexSim 23.0.4 ]
Hi DevTeam,
Flexsim crashes when we copy the label name to a code editor field. Attached is the video.
Arun KR
Replies (13)
Message 2 of 14
kavika_faleumu
Hey @Arun Kr, I followed the steps in your video for FlexSim 23.0.4 and it seems to work fine for me. Do you have a more specific set of replications steps I could follow or maybe a model you could post that you get this behavior on?
My replication steps:
  1. Start a new model. Drag out a processor.
  2. Create a label on the processor (presumably with "String" data).
  3. Open a code editor (like Send to Port on the processor).
  4. Double click the label name and press Ctrl+C to copy the label name.
  5. Paste that name into the code editor.
Message 3 of 14
arunTTT2P
Thanks.The steps are correct. But for me, Flexsim's crashing. Attaching a sample model also.crashtest.fsm
The same issue happens with 23.02.
Arun KR
Message 4 of 14
jason_lightfootVL7B4
Pastes fine for me. Did you try reinstalling FlexSim? Do you run other applications that use the scintilla editor, or have a clipboard manager running?
Message 5 of 14
arunTTT2P
The clipboard manager is not running. I don't have any other software which uses scintilla editor. Did Flexsim reinstall and issue persist
Message 6 of 14
kavika_faleumu
Have you tried updating to the latest version of 23? (23.0.5). Maybe that will fix your issue.
Message 7 of 14
arunTTT2P
Tried some more tests. For me
FlexSim will not Crash:
1. Drag-drop processor/ any object
2. Add any label
3. Copy the label name
4. Click on the 3dmodel space, then open the code editor
5. Paste the label name
FlexSim Will Crash:
1.Drag-drop processor/ any object
2. Add any label
3. Open the code editor
4. Copy the label name
5. Click on the code editor only, without clicking on any other window
6. Paste the label name
Message 8 of 14
kavika_faleumu
I followed your test and I get no errors.
Message 9 of 14
arunTTT2P
Can you try the same in the light theme? For me in the dark theme, FlexSim is not crashing
Message 10 of 14
kavika_faleumu
I get the same results, FlexSim does not crash.
Message 11 of 14
hsiangchao
I have the same issue, FlexSim will crash in version 23.0.5.
Message 12 of 14
JordanLJohnson
I was able to replicate this bug. I was able to fix it in debug mode on my computer. When the next bug fix release comes out, please let us know if it still occurs.
Jordan Johnson
Principal Software Engineer
Message 13 of 14
arunTTT2P
Thanks, @Jordan Johnson, and I will let you know if it occurs again.
Message 14 of 14
Matthew_Gillespie
@Arun Kr This issue is fixed in 22.0.15 and 23.0.6 released today.
Matthew Gillespie
FlexSim Software Developer
