[ FlexSim 17.1.4 ]
Hello Community,
I tried and tested a lot to get @Logan Gold 's old Socket Example working. I know it's build up with Version 7.4 and I'm using Version 17.1.4, but I thought that would be no big deal.
So I can get the connection between the two FlexSim Instances running (Server and Client). Otherwise the FlexSim Server Instance would be countinuing freezing. But the problem now is that I can't send/receive information between the instances. I tried to debug a lot with Console Printouts and after reading the error messages I found out that the "serverreceive(...)" command is not returning a string. It's a double with "0" in it. In the Command Help is defined that it must be a string executed by FlexScript (and the Script Command Console is only working with FlexScript). So why do I don't get a string with the "Hello World!" message? Maybe someone can test it on his system.
The error message is as in the picture:
Regards Robin
