FlexSim Run Speed Slider
javier_pl
Message 1 of 21
javier_pl
[ FlexSim 19.0.0 ]
Hi there,
I got a model developed in FlexSim 19.0.0 and tried to upgrade it to the latest version of FlexSim (20.0.0 and so on). The model units are defined as hours for visualization purposes, although most tasks' durations are of the order of days. After upgrading without (almost) any issue, I set the Run Speed Slider as always to sufficiently advance the model while visualizing part of the movements that take place in it (Max. Speed does not suit me, as it ends the model run almost immediately). However, it advances much more slowly than in 19.0.0 version. Then I saw this within 19.2.0 release notes:
"Changed the run speed slider to behave as a ratio of real time instead of model units per second"
Well, so I tried to create a simple day-based model and run it but, even setting the speed (via the slider) to a very high value, time passes by extremely slowly, since it behaves now as a ratio of real time.
So, my question is, does it mean that now every time I need to set a higher speed I have to use the Custom Value option in the pop-up? (That would be really annoying and would also slower the modelling in my case)
Does it make sense for the speed slider to be in accordance with that ratio? Even if model units are days?
Thanks in advance, Javi
Replies (20)
Message 21 of 21
Matthew_Gillespie
We updated the Run Speed slider in 20.2 so that you can specify the model unit ratio that the slider uses:
Matthew Gillespie
FlexSim Software Developer
