Flexsim hangs when compiling Flexscript
sastanin
sastanin
[ FlexSim 17.0.2 ]
Flexsim completely freezes when compiling Flexscript if there is a function-like macro and the name of the local non-existent variable is the same as the name of the macro parameter:
#define foo(x) (x)
// return foo(1); // OK.
// return foo(undefined); // OK. Compilation error.
return foo(x); // BUG. Flexsim freezes.
Flexsim becomes unresponsive, but continues running and allocates more and more memory over time. If there was any work in progress (a model), it cannot be saved.
Creating a local variable with the same name or using a local scope is not helpful. It appears that macro parameters use the same namespace as the local variables and take precedence over them.
#define foo(x) (x)
    int x = 3;
Matthew_Gillespie
Thanks for pointing this out. The best way to submit bug reports like this is to email the developers at dev@flexsim.com.
This article discusses best practices for submitting bug reports and feature requests.
How do I submit feature requests or bug reports?
Matthew Gillespie
FlexSim Software Developer
Matthew_Gillespie
This has been fixed for 17.0.4.
Matthew Gillespie
