Flexsim animation
Flexsim animation
osama_a6
Flexsim animation
osama_a6
[ FlexSim 21.2.1 ]
Where I can find Flexsim animation? please post a screenshot
Ben_WilsonADSK
Click on the object for which you want to customize an animation. Right click the object. From the popup context menu choose Edit, then Animations.
This will open the Animations and Components interface for this object.
1638542382818.pngYou can use the ? (help) button (marked with an arrow in the above screenshot) to open the User Manual entry (linked here) for this tool.
You can also get to the animation tools from an object's properties. If you left click on an object, its properties will open in the Quick Properties pane. Under the Visuals category, click the button for More Visuals.
At the heading Visuals/Animations, click the Edit button.
This linked Answers post includes some older tutorials that cover the animation creator. The UI may be slightly different in newer FlexSim versions, but the concepts should be the same.
osama_a6
Thank you so much. What type of 3D image (CAD) extension does the Flexsim animation accept?
