FlexSim and VR
FlexSim and VR
supportPHJ4A
FlexSim and VR
supportPHJ4A
[ FlexSim 22.2.1 ]
In VR mode, can FlexSim open a preset roaming path through commands or codes for display?
jason_lightfootVL7B4
Are you asking to store preferences for VR views? Please describe further what you're trying to achieve.
supportPHJ4A
Similar to what you said, the problem I am encountering now is that it is troublesome to use VR to adjust the viewing angle of FlexSim. Is there any other way to fix some viewing angles for display?
You can save viewpoints and attributes in the Properties pane. While you can also change the field of view angle in the tree and the save that with the view I think this is not good for VR and may even be overwritten to match your headset so that it's a fixed/correct FoV (would need to check).
supportPHJ4A
Thanks for your answer, I have a general idea
