FlexSim 2024 crashes when enabling VR after NVIDIA driver update (v591.74)
FlexSim Version: FlexSim 2024
Operating System: Windows 64-bit
GPU Driver: NVIDIA driver 591.74 (installed via the NVIDIA App)
VR Devices: Meta Quest 3S, Meta Rift
Description:
After updating the NVIDIA GPU driver to version 591.74, an issue occurs in FlexSim 2024 when VR mode is enabled.
When a VR headset (Meta Quest 3S or Meta Rift) is connected and VR mode is activated inside FlexSim, the application closes automatically without displaying any error message.
This issue did not occur before the NVIDIA driver update and appears to be related to the VR initialization process.
Steps to Reproduce:
Install NVIDIA driver version 591.74 using the NVIDIA App
Connect a VR headset (Meta Quest 3S or Meta Rift)
Launch FlexSim 2024
Open any simulation and enable VR mode
FlexSim closes automatically
Expected Result:
FlexSim should successfully enter VR mode and continue running normally.
Actual Result:
FlexSim closes immediately after VR mode is enabled.
Tested Hardware:
Machine G5
CPU: Intel Core i7-9750H @ 2.60 GHz
RAM: 32 GB
OS: Windows 64-bit
Machine G15
CPU: 13th Gen Intel Core i7-13650HX @ 2.60 GHz
RAM: 32 GB
OS: Windows 64-bit
The issue occurs consistently on both machines.
Could you please advise on how to resolve this issue?
Is this a known compatibility problem between FlexSim 2024, VR mode, and NVIDIA driver version 591.74?
Any guidance, recommended settings, or workaround (such as using a specific driver version or configuration changes) would be greatly appreciated.
Thank you in advance for your support.
