FlexScript: How to obtain the object selected?
jouky_d
jouky_d
[ FlexSim 23.2.1 ]
Hello everyone,
I am trying to know which object is selected (selected in yellow (click), not in red (control click)). I know there is the funcition: switch_selected(Object, -1) to know if is selected (with control + Click) or not. But how do I know which object is selected with only a Click? Is there a function for that?
Thank you!
arunTTT2P
selectedobject(activedocumentnode());
jouky_d
How do I choose the Model view instead of using activedocumentnode()? If I use it and I am on another view, the script returns error. I have searched on the View treenode, however, I didn't find anything.
jouky_d
I found it! it's using:
treenode TN = ownerobject(views().find("active>Documents/Perspective/1").value);
return selectedobject(TN);
jason_lightfoot_adsk
Can you explain more about your intention here? Normally you have actions on the model object set the objectfocus so that you have a reference to it in your view. What is invoking the view? Why do you need to detect a subsequent click on an object? Should the object be handling the click?
jouky_d
Hi @Jason Lightfoot! Simply, I wanted to call the object the user is selecting as a parameter of a function to be more userfriendly and to not insert all the parameters. The view is invoking the model. I need it to differentiate the selected by click and the selected by Control Click. (The question is solved).
Understood - thanks.
