FlexScript exception: Label property type retrieved on /Processor1/"1".
oussama_m
oussama_m
[ FlexSim 20.0.1 ]
test 5.fsm36759-capture.pngHello,I have a sample example of one machine. there are 5 items where each one is characterized by a processisng time with Normal (mean and deviation) distribution. These processing times are define in the table "TablePT". How can I define these values in the processor.
I obtained the error : time: 0.000000 exception: FlexScript exception: Label property type retrieved on /Processor1/"1". Label does not exist. at MODEL:/Processor1>variables/cycletime
The file is attached.
Thank you in advance for your help.
parker_s
It looks like you are trying to access the values in your TablePT using item.type which has not been set.
There are many places you can set labels on items, one of which is on the Source properties:
Add the "type" label on your Source1 like I've done here and your model will work.
