FlexScript exception - Label does not exist.
antonio_l
1 View
antonio_l
[ FlexSim 18.2.0 ]
Hi All,
this is my first review of FlexSim and my first model. I'm trying to model a system where two sources create two different parts. One part will be processed in a first Processor and the other to a second processor. If I include a "conditional port" or a "Port by case" in the output of the Queue between the sources and the processes I get this message in the system console everytime a part is processed:
time: 18.000000 exception: FlexScript exception: Label property Type retrieved on /Queue1/Box. Label does not exist. at MODEL:/Queue1>variables/sendtoport
Also, the system is not working as expected. What am I doing wrong?
Thank you.
roi_sn
Hello @Antonio L, would it be possible that you attach the model? Then, it could be seen what it is happening and help you.
gilbert_jerald
@Antonio L
Hi Antonio,
Port by case logic will work on the basis of label-value on the created item. The error that you get is because you didn't set a label value on the created item.
I have attached the model for your reference have a look at it.
support-1.fsm
antonio_l
Thank you gilbert jerald. That was the key.
The model you sent was very helpful.
Regards.
abraham_vo2
Hola que tal amigo @gilbert jerald . Un favor . Me podrías ayudar en una simulación parecida al error que le salió al amigo @Roi Sánchez
abraham_vo2
te dejo mi correo bro espero y me puedas ayudar abraham.vazquez1768@uppuebla.edu.mx
