Flexscript Errors preventing roller coaster model from compiling and running properly
schnauzervillage
schnauzervillage
[ FlexSim 16.0.1 ]
Im running the Roller coaster model and it loads ok and runs but will not compile properly.
The GUI reports do not update as expected with no riders loading and the av waiting time not updating.
I get this error in compiler console:
Flexscript ErrorMODEL:/RollerCoaster>variables/messagetrigger Line 65Pointer cast to an integer will lose its value in 64-bit. Use a double or preferrably a more type-safe method. for quite a few lines.
Plus this comment at the bottom:
Could not finish parsing because of previous errors.
arunTTT2P
Hi Peter Jones,
I have not looked at the model, most probably the error is because of initializing a variable as int instead of double in line 65.
For instance, the similar error can occur if you assign the number equivalent of an object to an integer variable. In those situations, assign the number equivalent as a double variable.
The number equivalent is made using tonum() command.
treenode object = node("Queue",model());// for example
int objectnum = tonum(object); // wrong way
double objectnum = tonum(object); // right way
Also, check the attached models. error-1.fsm error-removed.fsm
Arun KR
schnauzervillage
Arun
Thanks for your response I understand what to do but not where I can get to the script editor to fix the issue in the code.
I'm running on the free download EXPRESS and have no access to the script command console. Do I need to upgrade to enterprise to achieve this edit?
Regards
PJ
arunTTT2P
Hi Peter,
You should be able to view and change the code in the on message trigger of the roller coaster object. But you will not be able to save the model since flexsim express is having an object limit of 30 objects.
Also, in flexsim express version you won't be able to access any of the advanced features of flexsim(Eg.Script Console). So if you want to really modify the model and work you must use an enterprise license.
Arun KR
schnauzervillage
Hi Arun
Thanks for sticking with me on this. Your suggestions have helped me find where to edit the script.
However, when I edit the offending lines from "int" to "double" as per your previous post it still has issues.
Ive asked teh local reseller for help. If I get the solution I'll post the answer.
Thanks again - PJ
schnauzervillage
Arun
Actually - it worked! I just needed to close the editing panels after editing!
Brilliant - many thanks - I've even learnt something about advanced topics!
:-)) PJ
schnauzervillage
rollercoaster-pj-v1.fsm
Fixed if anyone wants it
