Finding breakpoint in large model?
rajankur6494
rajankur6494
[ FlexSim 23.2.2 ]
Hi Team,
I am getting "breakpoint reached" message while running optimizer after long time of 55 days. But I have no idea if there is any breakpoint was placed. I am checking it manually, but it is taking too much time in this.
Is there any automatic way to check it like using search or any other method?
What does the location mean in this message?
Thank you!
Jeanette_Fullmer
Hello @Ankur A3,
The development team has been notified of your issue. They would need to look further into your model to solve the issue.
If your model contains sensitive information, you could first toggle your post as private using the "make private" option under your question's "gear" menu. Private questions are visible only to site moderators. You can also contact your local FlexSim distributor for phone or email help. You can also email this with a description into the dev team.
rajankur6494
Ok, thanks for your response!
