Financial analysis, fixed and variable costs
jhon_alexander_sd
jhon_alexander_sd
[ FlexSim 20.2.3 ]
I need to do a fixed and variable cost analysis. I tried to use financial analysis but it didn't work. I want the payment of the operators to appear as a fixed cost and a variable cost for the maintenance of the racks, which is every month.
payment of operators = $ 1000
rack maintenance = $ 200 each month
16759-batch-picking-model-1-4-autosave-1_1.fsm
jason_lightfoot_adsk
There are guidelines in the manual here.
It says that fixed costs only happen once in the model and everything else is per time unit - which depends on your model setting - in your case minutes.
You costs should be entered in the amount per time, so that means $1000/30/1440 for the operators which comes to $0.02315 per minute. The racks are $0.00463.
After a month - that gives $6400.
Ben_WilsonADSK
Hi @Jhon Alexander SD, was jason.lightfoot's answer helpful? If so, please click the red "Accept" button on their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
