[ FlexSim 20.0.2 ]
Modeling does not work with messages in the system console windowsongpa.fsm
[ FlexSim 20.0.2 ]
We were able to get this model to open again without errors: songpa-fixed.fsm
The model had a lot of things configured incorrectly in the tree. Was this model built with a script?
I can't use script.
I did the work in the usual way.
During the operation, the screen suddenly stopped and did not work.
Dear @Matthew Gillespie.
Thank you for answer.
I and my customer want to know how to fix the problem model. I met the system console error message list when I opened the question model.
He said 'he leaved some minutes from his model during working and when he came back to his seat the model stopped, and then he could not do anything'.
We want to know how to fix it in detail.
We ran a script like this on the model:
treenode system = Model.find("ConveyorSystem"); getvarnode(system, "conveyors").subnodes.clear(); getvarnode(system, "conveyorPoints").subnodes.clear(); forobjecttreeunder(model()) { treenode obj = a; if(!isclasstype(obj, "Conveyor::Conveyor")) continue; treenode convSystem = getvarnode(obj, "system").first; if(convSystem && !convSystem.value) convSystem.destroy(); treenode points = getvarnode(obj, "conveyorPoints"); for(int i = points.subnodes.length; i > 0; i--) { treenode point = points.subnodes; if(isclasstype(point, "Conveyor::ConveyorTransfer")) point.destroy(); } } treenode broken = Model.find("BasicFR877"); if(broken) broken.destroy(); resetmodel(); forobjecttreeunder(model()) { treenode obj = a; if(!isclasstype(obj, "Conveyor::Conveyor")) continue; function_s(obj, "finalizeSpatialChanges"); }
