FelxSim webserver not showing the CAD layout
vignesh_s
vignesh_s
[ FlexSim 22.1.0 ]
layout.pngI would like to know if there is any mode in FlexSim to be enabled in order to show the cad model background layout in FlexSim webserver. Because I can see the layout in FlexSim model but when the same model is opened in webserver the model doesn't show the CAD layout. Please let me know if FlexSim webserver we can enable to see the CAD layout options. Attaching sample image of layout im expecting the same in FlexSim webserver
JordanLJohnson
On this page, you can read about the two ways to show a 3D view in the webserver:
https://docs.flexsim.com/en/22.1/Reference/DeveloperAdvancedUser/Webserver/Webserver.html
If you are using WebGL Streaming, then you won't see the CAD layout; it's not a (currently) supported feature of the webserver.
If you use Video Streaming, then you will see the CAD layout. However, Video Streaming requires rendering the image on the server, and sending that image to the client; it can be a bit more fuzzy in this mode.
Jordan Johnson
Principal Software Engineer
kavika_faleumu
Hi @vigneshs, was Jordan Johnson's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
