Export and import data using database SQL server
aravind_d
aravind_d
[ FlexSim 19.2.0 ]
Hi @Joshua S
I have to import and export a data using database sql server. I have founded that you have provided a step by step tutorial in this attached answer
https://answers.flexsim.com/questions/57206/export-and-import-data-using-database-sql-server.html
but the link provided by @Joshua S is showing access denied( https://answers.flexsim.com/articles/21711/sql-tutorial-step-by-step-model-construction-30.html )
can you give the step by step tutorial for sql server.
Thankyou in advance
joshua_s
I didn't actually create that tutorial, whoever originally posted it might have deleted it. I would go through what the manual has, it explains a lot and then there are commands if you want to more customization. The reference for those commands are at the end of the manual page.
https://docs.flexsim.com/en/19.2/Reference/Tools/DatabaseConnectors/
joerg_vogel_HsH
Updated Link: https://docs.flexsim.com/en/19.2/Reference/Tools/DatabaseConnectors/DatabaseConnectors.html
Actual links need to subdomain docs.flexsim.com in an URL as an endpoint a document. A directory path is not sufficient anymore.
