Experiments Re Run the same replication again and again.
pinakin_k
pinakin_k
[ FlexSim 22.0.1 ]
Hi, When the experimentation is complete the replications restart to run. However the results are displayed correctly and even for the 0% complete i have the correct outcome. So technically my experimentation never ends. i have to stop it to get the results.
What could be the reason of this.
JordanLJohnson
@Pinakin K I haven't seen that behavior before. Can you share a model that demonstrates the problem?
Jordan Johnson
Principal Software Engineer
pinakin_k
Hi I cannot share the model. But let me see if i can replicate it in a smaller one.
This is what's happening:
jason_lightfoot_adsk
Can you post the smaller model? If needed you can make this post private so only FlexSim can see it.
Are you running distributed experiments or even two experimenters on the same machine at the same time?
JordanLJohnson
@Pinakin K I don't know if there's anything I can figure out without a model. Do you get this behavior on a different computer? Does this issue affect all experiments on this computer? If not, can you think of anything that makes this model different from other models?
Jordan Johnson
ryan_c10
Hi @Pinakin K,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
