[ FlexSim HC 5.1.0 ]
I am trying to build a model to test out two different floor plans. I have built out both models and saved the layouts. I have noticed that when I switch between model views the distance between the nodes does not update unless I save the model.
When I try to run experiments between the two models it does not appear that adjusted distances are being used. If I switch between the scenarios in the explore tab after running experiments there is no change to the distances between nodes, again leading me to believe the distances aren't changing.
Is there any way to force the software to recalculate the distances between nodes in between scenarios? Or do I need to save the model manually between different runs of the experimenter?
Thank you!
