Experimenter results
chuoTV3H9
chuoTV3H9
[ FlexSim 19.2.2 ]
In the Experimenter tool, under the "Performance Measures" tab (performance-measures.jpg), I have specified a label for the y-axis of the plot. However, when viewing the results, the label is not referenced in the y-axis of the replications plot (results1.jpg), nor is it shown in the x-axis of the frequency histogram (results2.jpg).
I'm wondering if this is something that is still in development, or if I missed something to show the units of measure.
Thank you!
tanner_p
@Steven C7,
I'm not sure right off the bat if there is a way to show these axis labels. That said, however, you could export the data and add the labels post-experimentation in FlexSim. I know that might require a bit more work, though.
I also notified our stats developer to see what his take is.
chuoTV3H9
Thanks @tanner.p
The temporary work-around I'm doing right now is copying the raw data results into a spreadsheet, and processing them in a different software to create the graphs. However, I'm also interested to know what the stats developer thinks.
JordanLJohnson
This looks like a bug. There is code to draw the y-axis title, but the value to draw is blank, so nothing is drawn. I will put it on the dev list.
Jordan Johnson
Principal Software Engineer
