Experimenter Issue
Experimenter Issue
ChelseaC
Experimenter Issue
ChelseaC
[ FlexSim 23.2.2 ]
While we are running our first scenerio, it only runs several iterations it does not run the 30 iterations it runs a maximum of 3 iterations, but it runs them very slowly. What would the computer specs compatible to run the model?
joerg_vogel_HsH
You can estimate a needed performance capacity by analyzing your computer efficiency for a single simulation run without any experimenter use. Each additional simulation run needs roughly the same resources as a single model run. You will notice that your system has much more available CPU cores than needed Memory. You can restrict in Experimenter setup, how many cores you allow to use simultaneously. Typically you start with a small number of cores like one or two. If there are still resources available beside CPU cores you can increase the number of CPU cores by one in each new test. If your system runs by high performance with a power of 80 percent for a longer time, you will notice that you hear your cooling system components are getting louder. This will tell you that your system is going to reduce its efficiency. You have to find a balance of low thermal exhaust and high performance power, because your system can switch the core cycle frequency automatically to reduce the efficiency to be near 30% of maximum power. If you can keep the core frequency high before it shuts lower automatically you win. It depends much on the current actual room temperature which will rise by long simulation runs. Your system will heat up your environment.
ChelseaC
How can I modify the number of cores that the experimenter is using? Thanks for the info.
joerg_vogel_HsH
ChelseaC
For the FlexSim HC Student competition how many cores do I need to and how much memory do I need for it to run correctly?
Jeanette_Fullmer
Hello @ChelseaC,
In Joerg's comment above he has described how you can measure what a single run of your model takes RAM wise. For every replications you run at a time it will take about that much RAM and a core. You will have to look at the specs of your machine and the model to determine for yourself what would be optimal.
jason_lightfoot_adsk
Hi @ChelseaC, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
