Experimenter is not random
jia_yu_l
jia_yu_l
[ FlexSim 20.0.10 ]
We tried the experimenter to test the various numbers of AGVs, we replicate 30 times, but the experimental results did not seem to be very random? We ran the model ten times seemed more random than experimenter , This is not what we expected.
jason_lightfootVL7B4
Is your model deterministic or are there random variates in it?
Does it repeat if you reset and run the model manually?
mischa_spelt
The fact that you have 'blocks' of 8 replications with exactly the same result makes me suspicious. That sounds like all replications that started at the same time are giving the same result. Are you manually initializing any random streams?
Jeanette_Fullmer
Hi @Jia_yu L,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
