Experiment Scenario Slow Initialization
Melencolia
Melencolia
[ FlexSim 24.1.0 ]
Hi, I am using "Experiment" to analyze different scenarios. The problem I'm having is that the model becomes very slow if more scenarios are specified. It takes really fast with 100 scenarios, but if I try to set number scenarios to 2000 or more (I have 12000 scenarios total) the software become really slow and cant even finish setting scenarios. And this is only a simple 1 queue model. Can anyone help me with this problem? If this is a program level problem which cant be solved, is there any way to run it in batch (Like control the software simulation via python) as run 120 times with 100 scenarios manually is troublesome.
One Stage1.fsm
Jeanette_Fullmer
Hello @Melencolia,
For starters you probably need to look into range-based experiments.
We were able to see that it takes time to create 12000 scenarios and were able to identify some ways to speed up the creation. However, the scenarios per experiment is not limited on the Jobs tab but on the Run tab. The Run tab is limited in how much it can draw. For this reason, we suggest you limit an experiment job to 1000 entries.
logan_gold
Hi @Melencolia, was Jeanette F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
