An exit transfer is created when an a-connection from the conveyor to another object is added. If you only need the transfer and not the connection (for example if you use Process Flow to control the item transportation) disconnect the object again starting at the transfer. (If you disconnect starting from the conveyor the transfer is removed.)
Hi @Douglas Lima, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
