Existence of an attribute
marco_baccalaro
marco_baccalaro
[ FlexSim 18.0.4 ]
I have this code that returns <no path>:
Object box = model().find("Tools/FlowItemBin/Box/Box");
treenode itemBehaviour = box.attrs.behaviour;
return itemBehaviour;
But this code returns "It exists":
if (itemBehaviour)
	return "It exists";
else
	return "It does not exist";
It returns "It does not exist" if I change the second row to:
treenode itemBehaviour = box.find(">behaviour");
Why does this happen? Is it because those are hashed nodes?
Matthew_Gillespie
This is a bug that we'll be fixing soon, but the issue is that currently box.attrs.behaviour is exactly the same as calling behaviour(box). This, like all the old commands that return a treenode, will return saferef instead of returning a null treenode.
So currently, if you use box.attrs.behaviour, you need to treat it like an old command and use if(objectexists(itemBehaviour)).
You could also use box.attrs.find("behaviour").
We'll be fixing the attrs property so that it no longer returns saferef when the attribute doesn't exist.
Matthew Gillespie
FlexSim Software Developer
marco_baccalaro
Good! Thanks for the detailed explanation.
