Exception concerning overriding the return value
Lili
Lili
[ FlexSim 22.2.0 ]
Hi everyone
I'm new to flexsim process flow and I'm not sure why I'm getting this exception:
exception: Error: Event-Triggered Source activity Source" in "ProcessFlow" attempted to override the return value but a Finish activity was not hit or did not specify a Return Value.
It doesn't stop the model from running but I want to know if I can improve my modeling.
PS: My second acquire crane activity doesn't work after the first token and I don't know where the problem is.
Thanks in advance for any answers or comments
test2.fsm
jason_lightfoot_adsk
Check the section "Will override return value" just above the Change Rule section here.
Lili
Thank you so much @Jason Lightfoot Problem solved!
Any idea why the second crane doesn't move after transporting the first flow item?
You don't release it.
Lili
Thanks very much!
