Exception caught when redirect AGV
neil841027TTD9C
neil841027TTD9C
[ FlexSim 21.2.0 ]
I think the problem happened bacause of redirect() function,but I can't figure out why.
I try to redirect the AGV to another control point when it block the other AGV.
The code is written in On AGV Allocation Failed event.
Does anyone have an idea how to solve this?
Thanks!
test.fsm
moehlmann_fe
The exception likely occurs because of using "redirect" while the blocking AGV is currently idle. It will make the AGV move, however it won't create a task sequence, which in turn probably causes an exception when the AGV arrives at the redirect destination.
If, instead of redirecting, you create a task sequence for the AGV to travel to the destination this won't occur.
Another issue seems to be that you use "agv.accumAheadAGV" to get a reference to the blocking AGV. However, if the blocking AGV is situated on a different path, sufficiently far ahead of the current AGV, this command will return NULL. So I would recommend to get a reference to the blocking AGV through other means. In the attached model I use the nodes that link the cp to the AGV (cp -> allocations -> AGV reference in navigator -> AGV). There might be a nicer way to do this, but it works for now.
pushBlockerAGV.fsm
neil841027TTD9C
Thank you ,that's what I need!
