Exception caught in createundorecord() undocode 6
sebastian_canas9DYX7
[ FlexSim 21.2.4 ]
Hi all,
While I was building and making changes to a model the following error started to pop up
For a task sequence I was using an operator with a transpalet to transport flowitems for one point to another. In Process Flow I used some activities to make the operator take the transpalet: Source, Move Object, Change Visual, Sink. I set the operator as a Resource and I acquired it for the task sequence, changing also the parameter Count to duplicate the operator
Since I didn't find convenient this approach to my purpose, I changed the operator for a transporter, but everytime I try to delete the operator, the operator is deleted but this error pops up and when I reset the model, the operator shows up again on the grid.
I don't need a solution for this but I describe this situation in case is any useful to other users.
Modelo1_A.fsm
Jeanette_Fullmer
Hello @Sebastián Cañas,
I ran your model and did not have the same occurrence with an error upon deleting the operator and the operator reappearing on reset. Are you still having this problem?
Hello @Jeanette F ,
I'm not. I deleted the node of the operator and the error didn't appear anymore. Thank you!
