Exception caught error
leandroom
leandroom
[ FlexSim 24.1.0 ]
I am facing an error on my model but I am failing to understand why.
Could someone point out what did I do wrong?
error.fsm
moehlmann_fe
The Process Flow is moving the items out of the processors before the process has finished. When the finish event fires, the item it pertains to is longer inside the processor which causes the error. Use a Wait for Event activity to wait for the item finishing each step before loading it again.
leandroom
Thanks Felix!
JoaoDias
Hello, Leandro,
The error occurs because the item loading times in Process Flow conflict with the item's process time. A possible solution to the error is to use Wait for Event in Process Flow, so it will wait for an event (the item finishing being processed) to start the next activity, which will solve the error!
I hope I've helped!
