excel import
excel import
edwin_purwanto1
excel import
edwin_purwanto1
[ FlexSim 16.0.9 ]
I have a trouble when creating arrival schedule. The arrival sequence below, should resulted in 1 hour 45 product created, within 2 hour another 32 product created. But no, this resulted in 78 product created simultaneously within 0 second.
Did I do smething wrong?
Thanks and best regards,
Edwin
Jeanette_Fullmer
Hello @edwin purwanto,
The version of FlexSim that you are using has reached its End of Life. It is time to upgrade to a new and better version of FlexSim. Please, contact your local distributor to upgrade to the newest version of FlexSim.
Jeanette_Fullmer
As far as I understand the source options you have available to you in this version of FlexSim do not have the ablity to vary the arrival from what you have specified. You could use process flow and add a delay with a statistical distribution and then a create object activity.
In later versions of FlexSim there is a Date Time source that allows for you to specify arrival spacing and variation.
andrew_o2
Hi @edwin purwanto, was Jeanette F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
