Errors when using Conveyor modules
oliver_xie134
oliver_xie134
[ FlexSim 16.2.2 ]
hello , when i running a model which was builded with the conveyors modules , the following error conveyor-module-error.png apeared . Any recommendation on this issue would be appreciated!
philboboADSK
Can you build a new model with Conveyors? Does this only happen on that one model or any model with conveyors?
If it always happens with conveyors, then the issue and solution is probably the same as this question.
If it happens on a specific model, then we would need to see the model to debug why it is happening. You can post it in a private question if it contains sensitive information.
Phil BoBo
Sr. Manager, Software Development
oliver_xie134
hi phil.bobo
yes i can build a new model with conveyors, and it happened just in some model running. when the error happend, i aslo found some unnormol change in the MODEL:/ConveyorSystem treenode like following pic:
an invalid coupling data was inserted into the conveyorpoint node , and if i delete the invalid node , the model can run again from time the error appered. in some time later ,the same error would dispapped again. because i can't find the reference obj or node with this error , i don't know how to debug the model to find what is happening. can you give me a method on how to debug the model when i get this kind problem.
philboboADSK
Follow the steps in How can I debug a crashing FlexSim model?
Phil BoBo
